How to access putty on Linux Mint?
I just want to ask how to access Putty on Linux Mint? How to install and use Putty in Linux Mint? Please, I’ve been browsing all day just to find the right answer. Thank you so much.
Hello Mr. Richard
Regarding to your questions, installing Putty in Linux Mint has many steps.
First open the terminal on your pc.
Second type sudo apt-get install putty
Third, if you see the question “Do you want to continue?” just type Y and let the installation complete.
To access Putty on Linux Mint, just go to the Menu then click the internet button then click the SSH client. If a new window will appear click the save button. Don’t forget to put the IP address of the remote host then save it. And let the installation complete.
Hope this one can help you.
