How to access shared folder in Ubuntu
1. How can a shared folder on Ubuntu OS be accessed?
Please share the procedure for:
a. Connecting razer Carcharias microphone to Ubuntu.
b. Uninstalling Google Chrome unstable Dev channel.
To uninstall and remove Google chrome unstable Dev channel in Ubuntu, you need to type the details below in the terminal window run Sudo apt-get remove Google Chrome.
If you want to install a current version of Google chrome again, on the terminal window you need to type Sudo apt-get remove Google-Chrome-Stable .
In order to access shared folder in Ubuntu, you need to search for the pc name and copy the name using the IP address. If you are using Macintosh. In Finder do: Go – Connect to and then smb://name/user. You need to have the samba server configured correct though.
Notifications
