How to access sparus android control?
Hi Experts,
I am using a android application on my desktop.I need to go to sparus android control panel in it.Can you advice me on this android application and how to use it.Thanks.
Matland Maud
Hi Experts,
Matland Maud
Sparus everyWAN software is a remarkable tool that lets you see, tweak and control Windows Mobile devices using your own desktop PC's display, keyboard and mouse. It can be used for presenting or showing off your mobile device;s features on-screen or an a projector to a larger audience. (for eample launch shows, software demonstrations etc.)
It has a "file explorer" for transferring files between your mobile device and PC
It has a "task manager" for keeping track of processes, registry editing and providing help.
It also supports real-time functions such as drawing, voice-over etc.
It also has a new skin maker for your Windows Mobile device.
You see your phone on your PC and you can navigate the phone on screen.
Notifications
