How to access Windows Firewall with Advanced Security Console?
Hi experts,
I am trying to access the Windows Firewall with Advanced Security Console but I keep getting this error message:
How do I debug this issue? Does anyone know how to fix it?
Any help will be appreciated.
Thanks!
Best Answer by Gideon Yasti
Answered By 15 points N/A #137657
Hy,
There have few feature or option in windows which are not accessible without administrator permission. That is mainly for the extra security to keep secure. Actually you got error message in your computer for that reason which I mentioned above.
Now at first open the Connection Security Rules and then create a new rule. Then set your rule type and select Isolation option under the Rule Type tab. Then press next and then choose default, then press nest button on that window, now click on finish button which is located at the bottom of that window.
Hope you are understood
Answered By 0 points N/A #137658
Another solution could be resetting Windows Firewall with Advanced Security Console. However, consider saving your current firewall state. Find tabs for <Actions> then click <Export Policy>. You choose <Save as> create name and where to export file then <Save>. In restoring Default settings of Windows Firewall with Advanced Security Click (Restore Default Policy) follow on-screen instruction click <Yes>.
