joelabrame 10 points N/APosted on - 09/07/2012
Hi Experts,
I am having ms word 2007 and I need to achieve 500 one word substitution. I was using ms word 2003 earlier. So I have used word count feature on it. Does anyone know easy way to count word on ms word 2007. If so advice me on this. Thank you.
If you need to count the words in your document, you don’t need to install any program. You can do it right within Microsoft Office Word. First, compose your document in Microsoft Office Word. To check the current number of words in your document, press CTRL + A on your keyboard to select or highlight the entire contents of your composition.
On the bottom left corner of your screen, right above the “Start” menu, you should see something like “Words: 257/257”. This is the current word count of your document.
The value on the left of the slash (“/”) symbol is the number of words currently selected or highlighted while the value on the right is the total number of words in your document. You can also click this to bring up the “Word Count” dialog.
1....
