Hello friends,
How to activate gps on galaxy ace? I just got a new mobile phone which is a Samsung galaxy ace and was amazed by the features that android operating system can ever offer to those users. When accessing my facebook account using my mobile phone via wireless connection, my current location doesn’t appear in my status or wall, how can I configure this?
Thanks & Regards,
Timothy Raine.
lee hung
75 points
How to activate gps on Galaxy ace?
Well, you can either drop down the notification bar on your galaxy ace and turn the GPS on or Go to Home=>Menu=>Settings=>Location & security. From there check “Use wireless network” if you want to be located through your wireless network, or check “Use GPS satellites”. Your location services would then be on, and next time you post any status it will show your location as well. Hope this will work for you.
Hi
You want to get how to configure your GPS in your phone. This a easy task. There is two ways to get connected to the GPS:
1. By wireless network
2. By using GPS satellites
You can learn their configuration from the manual in this link.
Thanks
