sen jamie
Posted on - 06/04/2013
Hi, TechyV experts,
I would like to ask for your help.
I have been having several trips to different sides of our country lately.
I think it would be very helpful to my trio if I could use the GPS on my device.
However, I don't know how to activate this one.
Do you know how to activate the GPS on galaxy ace?
Please help me with this one.
How to activate gps on Galaxy ace? Any help
How are you,
Hope all is well with you. Nice piece of gadget you have. Samsung never seizes to impress their customers and fans with their unique products and services.
How to activate the GPS on Samsung Galaxy Ace:
Tap on the Menu key > Settings > Location and Security. Ensure the Use Wireless Networks check box is ticked. Read the Location Consent pop up message
Tap Agree
Ensure that the Use GPS Satellites check box is ticked
Press the Home key so as to return to the home screen
I myself own Galaxy Ace and enabling GPS is very easy.
Firstly you should have a data plan on your phone
Go to the main screen and bring your finger on the top (where clock, battery etc. Are mentioned.
Gently bring down your finger from top to bottom (drag)
GPS button is enabled in the middle. Tap it once to on.
Go to Menu and click on Maps. Now you can browse through places.
If you have a Samsung Galaxy Ace and you want to activate or enable the GPS, here’s how to do it. On your phone, tap menu then navigate to “Settings”, “Location and security” then select either “Use wireless networks” or “Use GPS satellites”. When the box is checked, the GPS is now active. And that’s it.
When you select “Use wireless networks”, your location will be determined by Wi-Fi connection or mobile network. This means your location will be identified using your mobile phone service provider. If you select “Use GPS satellites”, your location will be identified using the GPS satellite. This option is more accurate than the first option because it uses the satellite and it can identify the location up to street level.
