How to activate Kaspersky anti virus 2010 18 32
Hi. My Kaspersky anti virus 2010 is not working, how can I upgrade my Kaspersky anti virus 2010 18 32 to the 2013 without using any activation code? Thanks for the help.
Hi Susan,
It is not possible to upgrade your Kaspersky Anti-virus 2010 to Kaspersky Anti-virus 2013 without an activation code.
The activation code serves as proof that the software was purchased legally from the software vendor.
If you wish to upgrade your Kaspersky Anti-virus 2010 to 2013, you will need to purchase an activation code for it.
You may go to Kaspersky’s E-store to purchase a new activation code if it has expired or if you want to purchase a new one.
Another option here would be to purchase the Kaspersky Anti-virus 2013 to replace 2010 so you won’t need to upgrade your old software.
Alternatively, if you really don’t want to use an activation code, you can also get their free version of Kaspersky 2013 (click this link).
Pros:
Cons:
Nevertheless, it’s better to keep your computer protected for the next 30 days if you are a bit tight on the budget, this will also be a good enough time frame for you to decide if you want their full service. Hope this helps!Â
