How activate my PC wireless button and USB ports after formatting?
I formatted my PC and now the wireless button does not turn on my WIFI connectivity icon and bluetooth. It has also effected the front panel USB ports
Hey Hedda!
When you have formatted your Windows, it has formatted each and everything. Now when you have installed the New Operating System in your PC, make sure that you have completely update your drivers according to your windows. If the drivers of your Wi-Fi or Bluetooth are not properly installed, you will not be able to use your Wi-Fi and Bluetooth. I recommend you to use Driver Genius. It will update all your latest drivers according to your windows.
Once you installed the latest drivers, restart your computer and you will found your Wi-Fi and Bluetooth working.
Hope it can help you.
Thanks
Tunacao Caaron
Notifications
