How to activate NTFS Permissions in Windows XP?
I want to set permissions on my hard disk partitions,
I want to know how to activate NTFS permissions in Windows XP.
Experts please kindly help me
Sara Mccarthy:
Be sure the drive is NTFS.
Go to Start > Settings > Control Panel > Folder Options.
Click the View tab, scroll to the bottom and uncheck Use Simple File Sharing.
Click OK.
You should be able to grant NTFS permissions on files/folders now.
If not, try restarting and check again.
Hope this helps.
Experts i need your help again.
I want to know how to set permissions on a partition please kindly.
Sara Mccarthy :
Which permission you want to apply on your hard disk's partition?
