How to activate Opera auto reply in Opera Mail
Recently I started using Opera mail and I am loving it, I would like to know about the Opera auto reply and how to activate that when I am leaving for holidays.
Hi Markusa Raine,
To activate auto reply in opera mail, please refer following steps:
1. Click on options
2. Define Rules
3. Go to the section “Automatic Notification/forwarding
4. Then check the “Enable vacation Message box”
5. Then type auto reply message in the “vacation message text box”
Hope above mentioned solution will be helpful to you & Have a nice day
Thanks & Regards,
McKinney Ma
Dear Markusa Raine,
Hope you are well and still waiting for my suggestion. You need to follow some instruction to activate auto reply in Opera Mail. First of all, it is needed to define rules through clicking option. Then you need to enable vacation message text box by clicking on “Enable vacation Message box”. Finally click on “vacation message text box”. Yes now you have resolved your issue. Keep enjoying!
Best wishes-
Devid James
