How to activate remote playback audio on PC
When I am using remote desktop, I want to hear audio of the remote computer, how should I activate remote playback audio on PC
Hello there Dawn,
This problem can be easily fixed with a simple guide that I'll give you. All you need to do is :
1. Connect to your remote computer, make sure you have the correct details when you log in.
2. Click "Options" button in the bottom of the remote desktop window.
3. Click "Local Resources" tab near the top of the screen.
4. Click the drop down list in the "Remote computer sound" area and then select "Bring to this computer".
5. Click "Connect" button once done.
And there you go, you shouldn't have any more problems with not hearding sounds from your remote desk.
Waall Mike
You need to take the following steps.
Your audio will be enabled and you can hear the audio on remote desktop. Hope this will help you.
