How to add add Google talk to communicator?
Hello experts,
How to add Google talk to communicate? I got my Nokia communicator or shall I say a Smartphone and while trying to add Google talk the mobile system crashed and restarted. And some applications are gone. Is there a way to add Google talk to communicate? I would love to know more details on how to get this problem solved.
Thank you.
Best Answer by Kirsten Sosa
Answered By 5 points N/A #184638
If you want to use Google Talk on a Smartphone or Nokia, you should visit these websites to find a solution:
Thank you.
Answered By 0 points N/A #184639
Before doing anything on your phone make sure to back up your data first by going to the “main menu” then select “Application” click “File Manager” and select “Backup”. Following are the steps provided:
1. Go to main menu > application > select the mail icon.
2. Select “New Mailbox” then select “Exchange ActiveSync”.
3. You will then prompted to enter necessary details, key in your complete email address same thing with the password, then enter your complete email address on the “Username” then click “Next”.
4. It will then show you to enter the “Server Information” key in m.google.com and click “Next”.
5. Select “Options” then select “ Accept Permanently”.
6. You will then see a screen showing “what to sync”, select “Calendar” and “Contacts”.
7. Done.
You can also check this link
The setup is for Nokia S60 (Nokia E71 to the N95).
