How to add audio to website software? For example adobe Dreamweaver and other website software application, I want to add some mp4 file extension video and mp3 audio to my website using Dreamweaver. How will I upload those files and attached?
How to add audio and video to a website using Dreamweaver?
If you have to insert the audio or video object then, First of all you have to make an insertion point in your document window. Choose the insertion option according to your object.
• Click on the insert and select media.
• Or click on insert and select Interactive Image submenu.
• Drag your required button from the special / common category of object panel and place it in your desired location in the document.
It should be at the place where you want to show the audio/video file.
Or simply go to “Insert plugin” and select any one defined button of ActiveX, Shockwave and Flash to insert QuickTime audio/video file.
You can insert different multimedia type objects into your website using Dreamweaver. The first thing you do is to point to the area where you want your media placed. You then select INSERT – MEDIA OR INSERT – INTERACTIVE IMAGES submenu.
This takes you to a section where you can select different media objects, which can be anything from mp3 and other audio, mp4 or other video, as well as Flash, ActiveX and Shockwave objects.
It’s somehow not that simple to add sound to web pages. There isn’t a flashing button to add background music to your current Dreamweaver Web page. You didn’t go through a lot of trouble as well as there are no complex codes to study and use.
Here is how to add audio with a controller which allows music to play automatically when the page is opened.
1....
