How to add beautiful rotator banner?
Hi Experts,
I am using dreamviewer currently for web development.I want to add beautiful rotator banner for that web page.Can anyone tell me how get this done?I think  this is dealt with some graphics.Thanks.
Jafet Windsor
Answered By 10 points N/A #132770
Hello Jafet,
You will first of all need to create the rotator banner using a flash banner and then later on you will just embed it into the Dreamweaver code. Some of the flash banner applications that I will recommend including Aleo Flash Banner Maker or Flashbam. These applications can be downloaded for from the sites below. You therefore access the site and check them out.
After you have downloaded the application of your choice, make the banner putting in mind the dimensions you are using to design the website. After you are done creating, save the banner and then copy the copy that will be generated and them embed it into Dreamweaver.
Carl
