I have a web site, and I want to add calculator program in PHP scripting to my web site.
Before adding that to the site I want to make simple changes in calculator interface.
Please tell me how to download calculator program in PHP scripting and can I make that changes of its interface with my basic knowledge of PHP scripting?
How to add calculator program in php scripting to web page?
Hellow Trevor Weiss,
I am giving the sample PHPÂ Calculator code.
CODEÂ ATTACHED
Please customize it as your requirement.
Shifflett Laurel
Hi Trevor,
I have attached a text file containing PHP program, that you can use to create a calculator widget.
You can definitely use your PHP skills to change the interface of this calculator.
I would suggest you to view the link so as to how to change the interface of an already built calculator.
Hope this helps
Thanks
Baker
