bruce.max
50 points
Posted on - 08/14/2011
Hi Everyone,
I'm making a Customer Feedback Form for my clients in MS Word & I want to put the small check box in it.
Just like the Image below:
But I'm unable to find it in MS Word.Â
Please tell me, how can I put a check box in a MS Word document?
Please reply soon.
Thanks
Bruce
How to Add Check Box in MS Word
Bruce,
Cursor goes where you want to insert the check box. View – Toolbars – Forms. Click on the checkbox here and you'll get an unchecked box in your document. If you double-click this box, you can then select if you want it checked and if you do it will insert a check mark in the box.Â
Easy peasy.
Good luck
Michelle
Dear Bruce,
The best solution is here waiting for you:
Click view menu
Click tool bar
Click control toolbox
Now position the cursor where you insert the box then click the check box
If you want to rename the box (a) right click the check box (b) click check box object (c) click edit after that type the name
