Is using a CSS custom right arrow for select and dropdown menu, and everything working great, but the arrow on the right does not look like i want, i would like it to be wider.
So am thinking of setting background-image property in CSS (displayed default down arrow instead), but have no idea how doing that.
How to add CSS custom right arrow?
You can set the size and width of the arrow. You can use the background image property by using
Content: url ('some_path.png');
Or you can resize your image, save it and encode it in base 64 format and use it as:-
Content: url (data: image/png; base64, CAYAAAC3mX7tAAAACXBIWXMAAAsTAAALEwAA);
Encoding an image to base 64 can be done here- http://www.motobit.com/util/base64-decoder-encoder.asp
Regards.
Hi Fernando W Alvarez,
In CSS there are few types of background property, you can use the color background property and image background property. For the better, I show you both ways, you will choose your best,
Background-color property
Body {background-color: #b0c4de;}
Background Image
Body {background-image: url ('paper.gif');}
Background Image – Repeat Horizontally or Vertically
Body {background-image: url ('gradient2.png');}
Background Image – Set position and no-repeat
Body {background-image: url ('img_tree.png');background-repeat:no-repeat;}
Background – Shorthand property
Body {background: #ffffff url ('img_tree.png') no-repeat right top;}
Thanks for asking
