How to add custom CSS in blogger?please help
Hi guys, I want to know how to add customized CSS in blogger in order to give your blog a new look and more eye popping view.Please tell me is it possible to add customized CSS settings in blog as basically blogger aupports and runs much on HTML.Please help me thanks in advance.
Answered By 590495 points N/A #188389
If you know how to create a CSS file then adding a customized CSS on your blog would be a good idea because it will add a different feel and style in the way your blog looks. You can also control how texts or images are placed or presented. You can use it to resize big images without the need to physically resize the photo itself just to fit it in the web page.
Adding a customized CSS to your blog depends on the blogging site where you are signed up. For example, if you have an account in Typepad, adding your own custom CSS will be easy using the Custom CSS feature. Unfortunately, the Custom CSS feature in Typepad is available only to subscribers with Unlimited level and higher.
To use the Custom CSS feature to add your customized CSS, navigate to the Design area for your blog then click Add Custom CSS in the available options. On the next screen, type or paste your customized CSS on the text field and then save your changes. The customized CSS you added will be attached to the end of your existing stylesheet.
It will override any existing CSS properties that your default stylesheet have defined. This will also let you style the elements that were not particularly styled by the theme’s CSS.
