How to add design program event Photoshop?
Hi Experts,
I am having Photoshop on my desktop, but I am new to Photoshop.
I want to add design program event Photoshop.
Does anyone know how to achieve this?
May I require genuine version for this.
Jabez Zion
Best Answer by Hodge Trafton
Answered By 0 points N/A #132557
HI there,
I wanted to help you, so I searched the Internet and I found a couple of sites which may help us solve this problem.
I am also new to Photoshop, and I don`t use it very often, so this question will get things clear for me too.
Check this site out;
The downloads are safe, downloaded them myself.
Hope this helps,
Answered By 10 points N/A #132558
You can download plugin-in or filter that will compatible for Photoshop and other image editing programs.
Those add-on programs can provide beautiful images or effects for 3D/2D design that are hard to fulfill alone.
It is also the solutions for more creativity and enhance the quality of any images or graphics.
Here are the steps on how to install or use the plug-ins you download:
  1. Download the plug-in you want to use.
  2. Place or save it in the presets plug-ins folder of the Photoshop installation folder.
  3. Open your Photoshop and you are ready to use the plug-ins.
For the free, trial and paid plug-ins, try to browse the link below. It has 30 Photoshop plug-ins which you can get and create wonderful and standing designs. Those plug-ins are so useful and time-saving.
You can also get some tips and techniques on which are the best plug-ins you can use for your project or work.
