How To Add Gmail Calendar To Outlook:
I am using Outlook 2016. And I want to enable my Google calendar. Can anyone tell me how to add Gmail calendar to outlook?
You need to login in your Google calendar account to change the calendar settings.
Step 1: Go to the left pane and expand it and select the calendar that you want to add to your outlook.
Step 2: Now expand ‘My Calendars’ and open ‘Calendar settings’.
Step 3: Now go to,
Private Address———–>ICAL
Step 4: Now right-click on the web address displayed on the screen. Select the ‘Copy shortcut’.
Step 5: Now go to your Outlook and open,
File————–>Account Settings————>Account Settings
Step 6: Now go to ‘Internet Calendars’ and click ‘New’.
Step 7: Now paste the address you copied in the Step 4 in the window shown below and click ‘Add.’
Step 8: Now a dialog box will appear named as ‘Subscription options’. Mention the name of the calendar you want in your Outlook, and then press Ok.
