Hi Experts,
I need to add google cookie decrypter.I am currently using google chrome and I have set the browser to save cookies.Now a necessity has aroused to me to decrypt cookies.Does anyone know any decrypting algorithm.If so advice me.Thanks.
Peter Gonzalez
How to add Google cookie decrypter ?
I understand your concern and I am willing to give you some tip how to disable your cookies in your google chrome browser.
1.Go to "Tools menu" in your browser
2.Click on options and click "Under the hood"
3. Select "Cookie Setting"
4. "block all cookies"
And you can also download a cookie decrypter. Try this website and make the most out of it, consider the compatibility measures between the operating system and the application that you are going to download to avoid any interruptions and error while the downloading process is going on.
http://android.brothersoft.com/
