How to add HTML MSN button to my website?
I have a website and I would like to ask whether if I can add HTML MSN button to it in order for my readers and visitors to follow my RSS feeds to their MSN page. Please tell me how to do it. Thanks a lot.
Hello Matthew,
It is possible to add the MSN button to your website. You only need to have a link to your MSN page where you want your readers to view your RSS feeds.
Just obtain a link to your page and then add the button code to your webpage.
An example to add a button to a webpage can be as shown Attachment:
Thank you.
Hey Matthew,
Your readers and visitors can now follow your RSS feeds to their MSN page by using the HTML code attached. All you have to do is open the attached file and change the “YOUR ENCODED URL” into your URL. After that, copy the HTML code and paste it on your page. I hope this will be helpful.
Martine Paul
