Hi Experts,
I am having windows xp on my desktop and I need to add itunes screensaver linux to my desktop.I need step by step procedure to achieve this.I tried it on control panel but could not find the exact place.Thanks.
Jettphoenixx
How to add itunes screensaver linux to my desktop.
Greetings Jetphoenix! For you to use the itunes screensaver linux to your desktop you should make sure that you had already installed the screensaver into your computer. And then to set this as your screen saver you should do the following:
1. Go to desktop and rightclick
2. Choose properties
3. And then choose the screen saver tab.
4. In the drop down list choose or select the screen saver that you want to use. if it is the screensaver linux then choose it. click apply and ok. and its all done.
Hope this step by step guide help you solve your problem have a nice day!
