Any Hill
30 points
Posted on - 12/23/2012
Hi to everyone,
How to add a letter color icon?
I would like to edit and customize my own icon and change my game icon, folder icon, records icon and more.
I wish it is possible for me to make my own icon and make it as a default icon for a specific folder.
I hope you can find some ways for me to do it.
Thank you.
Your suggestion is very much welcome.
Hello there,
Good question though.
Well if you want to edit and customize the colour of your icons of folders and games all you need to do is Go to your Control Panel and in the Control Panel Search bar just type Colour Scheme and after than click on CHANGE WINDOWS COLOUR AND METRICS and customize it the way you want it.
For more help go through this Microsoft article in given link–
All the Best
Dear Any Hill,
There is a good easy way to customize specific shapes or colors for your special folders.
1. Click on the folder you wish to change its icon.
2. Make a right click on this folder.
3. Choose from the window that appears the bar of customize.
4. Choose folder options at the bottom of this new window.
5. You will find change icon click on it and choose the suitable icon for you.
