kurt pry
Posted on - 02/21/2013
I need help people. How do I add an open source cms shopping cart in my e-commerce website? I would like it to have a visually appealing user interface with payment gateways and shipping methods and EDI. I'm using Mozilla Firefox 18.0.1.
How to add open source cms shopping cart?
Hi there Kurt Pry,
The browser you are using will not make much difference, but a bit more information about your website would be much appreciated to give you the best solution.
Since I don't know what platform you are using for your e-commerce website, I will give you just a few very good open source shopping cart solutions.
My first recommendation would be the OpenCart. It is a simple but powerful shopping cart solution that will give you plenty of options and basically everything you need to start your online web shop. You can find it, review it and download it from the
https://www.opencart.com/.
Another would be the Quick.Cart by Open Solution. It is another open source shopping cart solution. It will not give you as many features as the Opencart, but is really simple, fast and just perfect for beginners and those who are looking for out of the box working solutions. You can find it on
http://opensolution.org/home.html.
No matter what solution you will choose, the installation is always the same – you will need to download the files from the developer's webpage, eventually unpack it on your computer, upload it to your web server and run the installation file through your browser.Â
