How to add picture to swf player ?
I am having a problem by inserting image on swf player . The swf player had no image before I clicked the play button .When I log on the page , the screen displays nothing . How can I add picture to swf player ? Please help me any one .
Answered By 70 points N/A #192931
Hello, Jhon.
There can be a lot of reasons why your screen displays nothing.
Maybe it works correctly on other browsers but you don't have flash plugin activated.
Maybe there is some mistake in your source code of the page, that can also always be a problem, one wrong punctuation is enough to cause page not working correctly.
Also maybe picture you want to insert is not copied to your web site folder or it isn't linked correctly. You must figure all aspects.
If you can't figure out where's the problem maybe this link can help you and release you of stress. There is a simple software with which you can create picture slideshow in an easy way and you can download it using the following link http://www.flash-slideshow-maker.com/download/ .
Goodluck.
