How to add pictures on swf file
Hello Guys, I am new to Flash and is studying by my own, Please do let me know about how to add pictures on swf file.
If you can provide tutorial on that regard, that will also help.
Thanks, Angela Martinez
Hi, Angela!
Since you are a beginner in using Flash, you must know you can always use the Help Section to find out whatever answers you may need.
For inserting pictures in flash when making, let's say, a simple logo banner you must go to the File menu, and then choose Import and then Import to Stage, after you previously selected the frame that you want to add an image to.
You can also use this below tutorial video to find out more about this subject.
Good luck with mastering Flash!
