How to add prestashop pop up message module
 Hello expert, I am going to create a website using Joomla. I need to increase the graphics and speed of it. I have an idea to add prestashop pop up message module when start the webpage. So please tell me how to add prestashop pop up message module into Joolma. Thanks.
Answered By 0 points N/A #198252
Hi Carolfhughes,
You know that Joomla is a popular Content Management System (CMS). It is easy to create a website by using Joomla or WordPress CMS. The both are popular now. Because generally no coding is required for creating a website by these two CMS.One can add different features by this CMS and you used Joomla for your website.
So you can add prestashop pop up message module easily.I don't describe the full steps here.But I give you some links below where you get full steps how you add prestashop pop up message module. The links are given below.
1. http://joomquery.com/simple-pop-up-joomla-module/
I think that the below link is more important for you.
2.https://shop.ddlx.org/en/home/295-message-pop-up.html
If you visit these given links, You can get your solution and you will successful.
Thanks
Taylor
