Good afternoon friends,
I want to give users an application or option in lotus so that they can add all there appointments and important meetings. So users, I just want some help from you in lotus script add a reminder. If anyone could help me with some scripting part or provide me some online tutorials from where I can take help.
How to add a reminder in lotus script.
Well, You don't need any script to make Lotus Notes to remind or gives you alert. IBM Lotus notes already have this feature under notify tab. You simply need to check the box and set the date and time, It will reminds you on the time , Which is set by users. Alarm can be set automatically, Plus sound can be played as well
To have Notes set alarms automatically:
1. Open the Calendar.
2. From the menu, choose actions – tools – preferences.
3. Click the Calendar, To Do tab, Then the alarms tab.
4. Select the enable the display of alarm notifications option.
5. Select the Calendar entry type,Alarms created automatically by placing a check mark next to it, then enter a time.
Now , I am giving you a link from where you can learn how to use all the notify features of Lotus notes.
https://oit.unlv.edu/unlvmail
Thanks
