Hi Experts,
I want to develop a website using php.I am not expert in php.So I need to add script ringtone maker php.I tried to get this by using php variable but could not achieve it.Can anyone give me the sample code to get this.Thanks.
Hollis Riley
How to add script ringtone maker php?
Hi Hollis,
I see that you want to develop a website and need to add script ringtone maker PHP. There are many ways to achieve this. A few solutions are:
1. Go to https://codecanyon.net/item/ringtone-maker/216373. You publish this ringtone maker on your website. You just have to buy the license for $8.00. They send you the code which you can use on your website.
2. Go to https://payhip.com/b/sfen This will cost you $25.99 but it is an amazing product.
3. Another one is from CobraScript; download the Ringtone Maker PhP Script.
