How to Add from server administration.
Hi users,
I want to upload media files (pictures and videos) from webservers. Is there any add from server administration plugins which allow me to import data from server admin, please let me know.
Hi users,
Hello, Austin!
To do this kind of job, you need to install remote server administration tools (RSAT). With this tool, you need to have privileges to connect to the server. You can change and modify using an administration account. I hope that with this solution your problem will be solved. If you have other issues, just keep visiting here.
Have a good day.
If you are just looking for a tool to upload and download files from a web server. You can use file transfer protocol. All you have to do is install ftp server software in your web server.
You can then use software like FileZilla to connect to your web server from anywhere and transfer files between these two systems.
Hope this info helps.
