I am having a ms powerpoint presentation and want to add simple smiley icon png to it.I tried to add it from the add picture tab but could not add it.I need advice on how to add simple smiley icon png from file to my presentation.Thanks.
How to add simple smiley icon png to my powerpoint presentation?
Dear Jaylonomarion,
  As the solution is more important to you, I will give you a benefited guide to do your work. You can do it with simple self study.
Please watch the below video carefully, how can do it. It shows the best way, which can be solved your question well.
However, if you need more details to study this, you can study 17 presentations and download more valuable things with using the below link. Then you can get,what is the best way to solve this question.
A Quiet Revolution in the World of Pages
Once upon a time every book left a trail. Bent spines dust jackets that never quite sat right paperbacks split at the seams. Shelves groaned under the...
1....
