Hi techyv,
How to add some invoice form in access 2007? I am using Visual basic programming language in my payroll system including different invoices, I would like to connect it to Ms Access database system. Is it possible for me to do that? If yes then how?
Hoping for your help. Thanks.
Invoice is a must to every business whether small or big company. To create an invoice in MS Access, On your Microsoft Access, select File, Time and Billing. You should look for it under the Office.com Template section. Should you have any difficulties finding Office.com Template, feel free to enter Office.com Templates keywords in the search box right in the upper right corner. Selecting Time and Billing Template should show you project list window. Select Reports and hit Invoice. Microsoft Default window information will open. Start making your invoice by filling out all the necessary fields.
