How to add some power widget lenovo?
Hi guys,
How to add some power widget Lenovo? I got the new Lenovo mobile phone and only got one widget on the screen. I have to add some application and also required to add a widget. Can you illustrate or show me the process of adding some power widget on the screen?
Expecting some help. Thank you.
Best Answer by parker_carter
Answered By 0 points N/A #182053
Lenovo mobile widget Zumobi site has recently launched new ones for generation people. You can also get a powerful widget like battery power widget from Lenovo. Fan how site here searching for a Lenovo meter power widget and click then read instructions step by step then install otherwise go to Lenovo mobile site raise ticket for new mobile gadget then support people will respond within the time.
Hope these shall help you
Thanks
Answered By 0 points N/A #182054
Hi Allison!
Here are the steps on adding applications in your phone.
  1. Sign-up for a Google Mail account. If you have an existing account, then use it.
  2. Open your phone’s web browser and go to the Android Market() or the Google Play Store (https://play.google.com/store/apps). If you have the Android Market application in your menu, simply click on it.
  3. Search using the keyword "power". You could find different power applications like Power Widget, Power Widget Lite, Power Manager, and Power Tune-up.
  4. Click on the application of your choice.
  5. Click on the install button.
  6. If the application is not free, add your paying scheme.
The application will instantly be downloaded and installed in your phone after you follow these steps.
