brian brian
20 points
Posted on - 03/28/2013
Hi expert, Iam using divx player. I played a movie video in divx player but the subtitle is not matching to the actual video, it means video and the subtitle file not playing parallelly. It has a few seconds delay in subtitle play. Can I adjust it ? If how to do that?
How to add subtitle in divx player
Hello Brian,
Here is your solution:-
Firstly you have to create a DivX Plus HD file by using DivX Converter 7,After then you can easily add your subtitles to the file using the steps below
1. At first you have to download and install MKVtoolnix from this link. After that you have to go to C:\Program Files\MKVtoolnix and open mmg.exe then drag your MKV file and your .srt file into the MKV merge application (or click the 'add' button and add them manually.
2. At last you have to set your desired output name and output location (and double check that the extension will be .mkv). Hit the 'start muxing' button.
Now you have a DivX HD file with subtitles. You can activate them in DivX Player. For this you have to opening the file, right clicking on the video, and selecting your desired subtitle track.
Hope you have got your solution.Best of luck.
