How to add swf file association?
Hello experts,
How to add swf file association? Well associating all files with any formats are not that easy. I just wondering if there are some application that will help us to get this done in a fast way. For example you do have so many swf file to associate. I hope you can give me the step by step process on how to get this done as soon as possible. Thank you.
Answered By 5 points N/A #179425
You can just use a converter or encoder to turn video files into flash videos(.swf).But first you should know that you can only perform this to video files with the following file formats: .avi; .ivf; .div; .divx; .mpg; .mpeg; .mpe; .mp4; .m4v; .webm; .wmv; .asf; .mov; .qt; .mts; .m2t; .m2ts; .mod; .tod; .vro; .dat; .3gp2; .3gpp; .3gp; .3g2; .dvr-ms; .flv; .f4v; .amv; .rm; .rmm; .rv; .rmvb; .ogv; .mkv; .ts.
Try this software out https://www.dvdvideosoft.com/guides/free-video-to-flash-converter.htm. Just drag and drop the files you want converted into that applications window then choose .swf as your output format.
