belensienna
10 points
Posted on - 09/07/2012
Hi Experts,
I am having PowerPoint presentation built on 2003 format.Now I have need to add template free wholesale to that presentation. Can anyone tell me how to add this.Will old version be a issue? Advice me on this issue.Thanks.
Belensienna
How add template free wholesale to PowerPoint presentation?
Good day!
If you’re just going to change the template, there would be some change if that template is built in with a master slide and layout slide.
Your slide will change its fonts and font size. There are a lot of changes to do. But that's just the issue. Now if you’re going to have another program like Open office for the slide. There is really a big change in your slide, many to edit and if you have time to edit its ok but if it’s a hectic schedule it a bad idea.
If you have time you can use PREZI it’s a good presentation you can just import you PowerPoint slide to PREZI.
Very easy to study, no hard time to adjust, here is the link
