Hi Experts,
I am having a login page on hi5.com.I want to add a template to that login page.Does anyone know how to add template with page member login.I need to add this template immediately so want steps to follow.Thank you.
Best Regards,
Orlaandoaddison
How to add template with page member login?
Add template to page in site by editing header and footer then other upload a template which can be download by artfans site create a header name of template before adding header and call server with post method then write footer with language quotes check loading page with directory of downloaded template and add to page you need.
Hope these shall helps you
Thanks
Hi Orlaandoaddison,
Here is an easy step to add a template to a website:
Open the website you wanted to add a template, make sure to put FTP at top so it will open the main folder.
If you have the code in hand it would be easier, if not look for a website once you found the template you want then just right click on any space and then right click and see view source. Save this code in a folder on your desktop.
Copy and paste the folder to the template folder on the FTP site.
Close the window and then once you open it again you should see your template there.
