How to add till slip font ?
Hi Experts,
I am having ms word 2007 in my desktop. I want to add till slip font to ms word 2007. I tried to add this font using control panel. But does not know in control panel where to add the fonts. Tell me the step by step guidelines for adding this font.
Cassandramariannaa
Best Answer by Davidson Mudge
Answered By 0 points N/A #141720
Good day!
If your are using Microsoft XP Operating System, these are the steps:
1. Go to Control Panel.
2. Choose Fonts.
3. Choose Add Font.
Then it will automatically install and be included in the fonts folder.
For windows 7:
2. Type in "Fonts" in the search toolbar at the upper right side.
3. Then just paste it inside the folder.
Hope it helped you!
Answered By 0 points N/A #141721
Hi Cassandramariannaa,
   If you would notice that when you download fonts online it is in a zip form. If you have an file extraction tool like WinRAR or WinZip you can use it to unzip the file then find the .TTF file just click it and it will ask you if you want to install the font, you can do it by clicking install at the upper part of the box. A status bar would show very quickly then you are done. Then just you Word 2007 and you should find the font there.
