How to add two monitor in one CPU ?
Now a day’s sometime we need more than one monitor at a time to see, and it is absolutely possible although some additional things are required but not always. If your computer run with windows you have to see wither your AGP or video card has dual output line of VGA port or not.
If it has you just have to connect two monitors with the two VGA port. If your video card do not have dual VGA port you have to buy a monitor switch box to connect two monitor. There is another way to connect two monitor which is expansive, you can buy another video card. I think you need the picture of VGA port.
Of course you can add two monitor in one CPU. By adding two monitors in one CPU you will get some extra advantages that one can serve. Here I will not say this advantages rather I listed the process of adding two monitors in one CPU and you need to:
1. Make the hardware hookups.
2. Install drivers if necessary.
3. Set up your second monitor.
4. Then adjust your monitor screen layout.
I hope this will help to add two monitors in a CPU. If you can't do that please let me know, I will try to provide another way to solve your problem.
Thank you.
