Hi Experts,
I am trying to add vbulletin gadgets to my laptop. I did research on internet to find vbulletin gadgets. It is easy if someone provide me clear step by step instructions to achieve this.
Jaylonomarion
How to add vbulletin gadgets ?
If the program you are saying here is the software from vBulletin® – “https://www.vbulletin.com/”, I think you are using an older version of the application that’s why it no longer works.
But to check if there is really no problem with your system, why not try doing another clean installation of the program to fix any corrupted files that are maybe affecting its functionality.
Uninstall your present version of vBulletin then restart your machine when asked. After booting, check your computer for any possible errors. Use a disk utility application to check the system.
For a much thorough diagnostics test on your computer, use disk utility applications like Norton Utilities, or Norton SystemWorks.
Install the program again then see if this fixes the problem. If it still doesn’t work, maybe you should upgrade to the latest version now.
Visit vBulletin® to download vBulletin 5 Connect. Just check the website for its pricing.
You should also check its FAQs or Frequently Asked Questions to know other facts as well as the system requirements.
