How to Add Video on YAMB?
I am running Windows 8 and I want to add my video on YAMB (Yet Another MP4Box UI), but I don't know much about this software. Can someone please provide some tutorials or help? Thanks!
Yet Another MP4Box UI can allow the user to create, split or join MP4 or 3GP video files. When you install YAMB, you can find four categories. These are the Creation, Editing, settings and About.
Creation is for making MP4 or 3GP files. Just simply select which format you wish to create as shown in the screen:
Then click on Editing and then double-click the option "Click to join supported files".
From there, you can now see the option to Add your video files. Just browse to your computer to the folder where your movie files are located:
When you insert your video, the filename will appear twice. The first one is for the video and the second one is for the audio. Just move each files to sort it in order using the Up and Down buttons in the right. But ensure that you will also move the audio file next to the correct video file with the same filename or you will not have the correct sound. And ensure that you change the Output name of your file below so you will not overwrite the first part. And then click Next to start meging your videos.
The process will take a while based on your video size and the speed of your computer. When you are done, click Finish.
