How to Add zabbix monitoring printer to my system.
Hi all experts,
I just bought a new Zabbix monitoring HP printer for my personal use. I wanted to connect this printer to my laptop, can anyone guide me how to add zabbix monitoring printer to my system, is there any drivers or software needed to use this printer.
Best Answer by John Doctorr
Answered By 10 points N/A #157912
Hello Boucher,
You didn't mention what type of OS you are using or What type of Laptop you are using. Anyway, for every printer there should be an installation CD and Guide. Then follow the guide. It's a normal process.
Or you can check this site, Adding and removing Windows 7 hardware.
Hope this will help you.
Thank you and have a good day.
Answered By 0 points N/A #157913
This solution provides you complete observation of horsepower server's hardware similar to you'd get into horsepower SIM, however victimization zabbix. The template solely uses horsepower WBEM suppliers and also the good Array Configuration Utility command line interface (not mandatory) therefore there's no got to install horsepower SIM or create any SNMP configuration.
The template uses active checks and then it works with servers that are behind NAT, while not the requirement to tack any port forwarding. Finally, this template works on low-end servers like ML110 that have embedded controllers and that horsepower SIM isn't accessible.
