How To Adding USB Port To Carmanually?
I am driving a Yaris to my office and most of the times I have my mobile device less charged. So I want to know about adding USB port to car. Is it possible from home or I may need to buy a new car?
No, you may not want to buy a new car instead you can just add a USB port as said to your car and to do that you will need the following materials.
• Snip
• Pliers
• Flashlight
• Gum
• Screwdrivers
• Soldering kit
• CAT-5 wiring
• Knife
• Drill bits
• 12v to USB Adapter
The above picture shows how a 12V to USB adapter looks.
This device needs to be added to your car and be placed to right position as your requirement. After placing you can cover it and clean the extra gum or soldering waste to make it look clean.
