How to adjust Google voice controls and active x?
Hi Experts,
I want to adjust google voice controls and active x.I am having google talk and need to know how to go to the settings of voice controls and active x?I tried it on account settings but could not find.Thanks.
Jafet Windsor
Answered By 0 points N/A #132766
Hi there,
I read a few pages and found out that you can adjust your settings through Google Talk client settings.
You can also adjust the volume by going to Start>Control Panel>Audio Settings(Sounds) and turn up or turn down the volume manually.
It also says here that if you are using Video chat in Google talk, you can use this link to make adjustments: https://support.google.com/chat/?visit_id=0-636509762102147109-4293325454&rd=1
regards,
