How to adjust setting on lenovo s100 bios reset?
Hi Expert,
I have a problem about some settings in my Lenovo desktop. I want to know some ways and process to adjust setting on Lenovo S 100 bios reset.
Thank you.
Hi Expert,
Thank you.
Hi Shannon Wheelock,
To adjust setting on your Lenovo s100, please press at first key “F1” from your keyboard. Now press “enter”. Now you have entered into your bios. You can reset your bios system from here and now you have to save the changed setting. I think my solution can help you.
The most common way that most of us Know and reset the BIOS password and eliminate the battery on the motherboard of a dixaine minute. Another method is to reset the CMOS reset jumper on the motherboard itself. Both of the 2 methods mentioned works because most Motherboard use a battery to remember the BIOS / CMOS settings in the motherboards PROM chip. Thus, cutting power to the battery settings BIOS / CMOS will be deleted.
