Hi Experts,
I want to adjust settings on EAN 14 CorelDraw to enhance the performance of coral tool. Does anyone know how to adjust the settings to suit my need. I want step by step procedure to achieve this.
Adolfojeremiah
How to adjust settings on ean 14 coreldraw ?
If you are experiencing some problems with your present program, try restarting your machine then try it again. See if the problem disappears after a reboot. If it doesn’t, you may try doing another clean installation of the program to fix any corrupted files that prevents it from working correctly.
Uninstall the application then restart your computer when asked. After booting, check your computer for any possible errors. Use a disk utility application to check the system. For a much thorough diagnostics test on your machine, use disk utility applications like Norton Utilities, or PC Tools Performance Toolkit. Install the program again then check if this fixes the problem.
To properly configure your application, you should go to its settings then adjust or change the options there to fine-tune the software’s functions and performance.
