merryl
Posted on - 11/11/2011
Every time I disconnect a speaker from my computer, the sound adjust tool in my desktop and control panel seem to be non-functional.
I experimented a little by adjusting through a radio station application but it does not seem to work.
Can you please give me an explanation as to why I cannot adjust the sounds without the speakers connected to my computer?Â
How to adjust the sounds without speaker connected to my computer?
You are using a Windows 7 operating system that is why it is not letting you adjust the sounds once you have disconnected it to your computer. The Windows 7 operating system, can auto detect the speakers or headset that is attach to the sound port of the computer, therefore once the device is unplugged it also automatically disables your sound adjustment. So I suggest that you just let your speaker attached to the computer so that you can adjust your sound normally.
Hope this answers your question regarding the sound adjustment matter. In XP and Vista it doesn't happen but I still suggest that you stick with your Windows 7 operating system.
When disconnecting the speaker out of your computer, it may change the sounds system's speaker settings. This is caused by the actual speaker's configuration that is link to make the audio installed working properly.
If the speaker is out, you can adjust the sound by doing the following steps below;
Look for speaker icon in the system tray, lower right beside the clock
Click on the speaker and go to Mixer
Adjust the speaker settings
You an adjust the System Sounds
Adjust the Rear Line In High Definitions Auto Codec
You can also click on the Speaker icon
Go to Properties and adjust the settings
You can also click on the Application icon
Then adjust the settings to your liking
You can also click on High Definition Codex
This allows you change the settings of the audio speaker
