Hello experts,
How to adjust winamp subtitle? This is the best music player that I ever used in my entire life but there are some features that I am not familiar with such as adjusting winamp subtitle. Can you give me a step by step instruction regarding this matter? Thank you experts.
Simplest way to adjust your winamp subtitle was go to edit -> timings -> adjust. this will adjust all the
times at once given the proper correct timing of the first and last subtitle.
If you need to adjust individual once, that's easy way .
or else use VisualSubSync software to adjust your winamp subtitle.
Hello Debra,
Don’t worry. You can simply adjust the subtitle from Edit – Timing – Adjust. You can adjust from this at once correct times are given. If you want to adjust individual, That’s going to help you definitely.
If you are tired on accurate adjusting, I suggest you to use VisualSubSync. You can download the it from here:
Hope this will help you. Have a good day.
